Edit: Sorry, guess I didn't think it through...
Code:I've got this interlaced PAL DVD source I want to encode. I want to get rid of the lowest line in the bottom field because of errors in that line. This would give me one 720x288 field and one 720x287 field. Are the different field heights going to be a problem when weaving? Here's the illustration: Legend: B-R = Bad line - remove O-R = OK line - removeI've got another source, from which I'd like to remove the highest two lines from the top field, the highest line from the bottom field, and the lowest line from the bottom field. I know if have to switch field order before weaving. I'm new to AviSynth, so I'm still a bit confused about what commands and parameters to use (despite viewing the tutorials).Code:TOP BOTTOM O ^ O | | . . 576 . lines O | O | B-R vCode:TOP BOTTOM B-R ^ O-R | B-R | O | O . 576 . lines . | O | O | B-R v
Just mask the bad areas -- Crop and AddBorders. Use at least mod4 when working with interlaced video. For example, in the second case:
Crop(0,-4,-0,-4).AddBorders(0,4,0,4)Last edited by jagabo; 20th Jul 2010 at 07:16.
AVIsynth -- how do I add an audio wav to a video only clip.. [SOLVED]
By vhelp in forum EditingReplies: 7Last Post: 19th Nov 2013, 06:27 -
General Resizing HEIGHT/Avisynth understanding
By Krelmaneck in forum Newbie / General discussionsReplies: 27Last Post: 25th Nov 2011, 01:46 -
is 1080p shown in Height in mediainfo?
By justravis in forum Newbie / General discussionsReplies: 8Last Post: 24th Feb 2011, 18:48 -
Rule of 16: is a divisible height as important?
By ptfigg in forum ffmpegX general discussionReplies: 1Last Post: 11th Jul 2008, 12:48 -
Changing width & height
By Blå_Mocka in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2008, 12:27
